azazel1024
A weird question to ask, but I am wondering about the durability of home networking gear. In particular, how close does one need to hew to the recommended temperature ranges in product listings?
Non-condensing environment, sure, crystal clear on what that would cause, but temperature range? How hard and fast?
The situation is I am looking at extending my network. I have a moderate sized property of a little over an acre and my router and WAP will not cover it. They cover my house just great, but depending on location, get more than about 20ft from the house itself and signal plumets and 50ft away its gone (except in the front down the driveway which has LOS out the living room window to the mailbox, which actually still has ~-60db 150ft from the WAP).
I have a shed in my backyard that is actually located within about 50ft of where I'd like to be getting signal (a "detatched" patio by my kids playground). The shed currently has power run to it (though not working, which I need to track down the issue there. Only bought the house a year ago). My thought was to use powerline adapters and then hook in the N300 bridge I happen to have laying around. Of course they'll be in an unconditioned shed, which means it could get cold. Tomorrow is "historic" lows for us, but call it 0F basically. Highs can sometimes get up around 100F or a couple of degrees warmer.
Is this likely to screw the networking gear? It'll be located in the shed so condensation/dew is not likely to be an issue at any point. It'll be constantly running so I'd think that the gear should keep itself warm enough not to be an issue, but I don't really want to bother with the attempt if the verdict is it'll likely freeze/fry itself.
