- Jan 19, 2001
- 62
- 0
- 0
I am engineering a home network, well, for my home... Anyways, I got a preliminary plan here, and it looks like there will be no problems with it, but I thought I'd post it here in case there are any major network guru's present who could offer tips, changes, etc.
A combination of 10/100mbps and full duplex hardware, as well as category 6 ethernet cable, will enable the network to run at 200mbps, or approximately 25 megabyte's per second. BTW, dont even bother trying to tell me I will probably not need semething this fast, as currently our basement is unfinished (as in no walls, but it will be finished relatively soon) and I would like this network to last as long as possible.
Anyways, the connection to the net is ADSL, from my local provider, Telus. The next device is the 3com HomeConnect ADSL Modem, which would in turn lead to the router, a LinkSys BEFSR41 (a four port Cable/DSL router). From there it will branch out to probably three computers initially, with more possible. Each computer has a 10/100 full duplex LAN card made by either 3com, LinkSys, or D-Link.
Since I am actually running cable in the walls, well, ceiling of the basement, actually, I will also be putting in network jacks, instead of loose cables. Now, of course I will make sure to use jacks capable of serving cat6 cable well. However, can anyone mention any tips for installing the jack box, crimping the cable into the plug, and anything else relevent to the jack installation (as well as any problems with my network plan above)?
Oh, and I am unsure if the LinkSys router can handle that speed, as I've been hearing some complaints about it in just the past couple days... So any experience with that would be helpful too.
Thanks, I appreciate any input.
