OK. My home network is configured as such:
4 computers:
SWITCH:
3 current connections -
DSL (into uplink port)
JOEYSROOM
WEBSERVER
The DSL line gives DHCP addresses to both Joeysroom and Webserver. In essense I have two DHCP addresses and both computer are connected directly to the Net.
SERVER (WEBSERVER):
2 network cards -
Linksys PNA - 192.168.0.1
Linksys Ethernet - DHCP plugged into switch
JOEYSROOM:
Linksys Ethernet - DHCP going into switch
LIVINGROOM:
Linksys PNA going into Webserver. DHCP address given by webserver. It gains Internet connectivity through Win2K NAT software.
MATTROOM:
Same config as above (Linksys PNA, DHCP addy given by webserver, uses NAT to get net access).
I had Joeysroom on both Ethernet and PNA before but I had to free up an extra PCI slot so I yanked the PNA card; everything works fine except that I want to force JOEYSROOM to get a DHCP address from WEBSERVER and hop over to Webserver before it gets out to the net. This is for security, and it saves me from having to set up two software firewalls.
The DHCP-subnet of my DSL is 255.255.248.0. The DHCP address is typically in the 4.3.169.xxx range. Is there any way I can force JOEYSROOM to travel through WEBSERVER first?
4 computers:
SWITCH:
JOEYSROOM
WEBSERVER
SERVER (WEBSERVER):
2 network cards -
JOEYSROOM:
LIVINGROOM:
MATTROOM:
