Home network - Cat 5e wiring help
salaku
Hi,
In my house I have ran the cat5e cable to 4 rooms. The cable is run in such a way that one end of all the 4 cables end at one place so that I can hook up my router, while the other ends are at Living, Study, Bedroom1 and bedroom2. Now how do I test the wiring and make sure all is working well. I will not have internet connection until atleast next week. Is there anyway I could test the cabling without internet connection? 🙁
I have to test this before I sign-off the paperwork for closing. Any suggestion would be really helpful.
Why you need Internet connection to test Network Wires?
You need network to test Network Wire.
Two computers one of each side of the wire consist a Network, if you can transfer files it Works.
Link to: Installing & Sharing
You want to measure?
You can buy an Instrument (look at the end of this page).
Link to: Wiring - I would like to wire my Networked Computers (Home Wiring).
Or you can use two computers with Qcheck.
Qcheck by Ixia
This Free tool is a subset of Chariot which is considered the Standard in evaluating Network Bandwidth connectivity.
Link to Product Description: A Free Utility for Network Troubleshooting from NetIQ!).
After reading the page, log here: Qcheck Download.
Scroll down to:
IxChariot
IxChariot Support & Downloads
Qcheck Download
Application Scanner
Click on Qcheck Download.
You have to give some personal info, but this Application really worth it.
Down load the Main program and a copy of the stand alone End Point.
Install the Master program on one computer (Main computer, or serve). Install the End point Client on all other computers on the Network.
:sun:
