Hi Guys- Tired of my kids whining about the wi-fi cutting out or getting slow occasionally (bedrooms only have wi-fi currently so they are gaming on wi-fi signal) - so I am now going to wire the house for a home network. I don't know why the internet it is cutting out as sometimes it comes back quickly, other times you have to reset the modem or the wireless or both, and other times you have to unplug th epower to the modem/router for 5 minutes then reset. This network will also solve another issue as I will be dropping Direct TV in February, but currently have no internet to my main floor TV viewing area. So with the new network I will have wired internet in that area for a new smart TV or Blue ray player or PC or all the above and will be able to watch movies, shows, etc via internet.
I will have the modem and router in the basement and run cat6 to the bedroom and other rooms in the basement directly via the drop ceiling. I will then then run 2 Cat6 wires to main floor inside the walls to study and multi-media tv area . TO get to the second floor I will have to go outside by running 3 cat6 wires out of basement into a PVC pipe that will run up the side of the house into to the attic and then run the wires individually down into the second floor walls to the three bedrooms- to a wall outlets.
Main questions are:
1) Need a good network switcher ( need 8 ports GB at least)
2) Current internet provider is Comcast - would like to buy a modem rather than renting theirs - their modem may be part of the problem- but I don't know for certain.
3) Need new router - my ASUS 660 maybe part of the problem it is 3 years old
4) suggestions on Internet tv services/plug in adapters, etc.
So far , the best place I have found to get the cat6 cable is at Mono price- other suggestions?
What is the max length of Cat 6 you can run without degrading the signal? I figure the longest I will have to run will be less than 100 feet.
How hard is it to make your own custom length Cat6? or should I just buy it long and not use all of it? ie) 4 x 50 foot and 3 x 100 foot lengths with ends already installed. This way I could also get different colors so know which is which for plugin into the switcher is easier.
50 foot = Cat6 Straight Cables - 50ft - Monoprice.com
100 foot = Cat6 Straight Cables - 100ft - Monoprice.com
Thanks in advance guys.
Main questions are:
