Home NAS Recommendation
cjp87
24
Sorry if this is a common topic for passers-through to post, but I can't seem to find a good old thread that mentions all of the things I'd like to know about in a recommendation.
I'm primarily looking for a home backup/media serving solution, though the media serving won't be super-intensive. Here's a checklist of the things I can think about wanting to do with it:
  • Backup both OS X and Windows laptops (Time Machine, Windows 8+). Being able to backup to the NAS over WAN would be great, but not necessary.
  • Store and access files over LAN as if they're local files (so just accessing them via Finder/Explorer)
  • Store and access files over WAN in the same manner (if possible-- if this isn't feasible, then no big deal)
  • Play stored media (music, videos) on OS X, Windows 8+, Windows RT, iOS, and Android devices (the more of these systems supported the better, I have devices using each of these OSes). This would just be over LAN. I have up to 1080p files, but if transcoding will bump up the price a whole lot, then I can just format the files as necessary before storing them.
  • Use Adobe Lightroom's Smart Preview feature (stores catalog with previews on local drive, RAW files on NAS).
I probably don't want to go over a 2-bay drive due to space, price, and power concerns. For the price range, I'm a little flexible, but obviously better value is appreciated. I'm shooting to stay under $300 without drives. Some that I've looked at include Synology's DS213j and DS214, as well as the Asustor AS-302T (there's an open-box model on Newegg for $250). But of course, I'm open to other suggestion as well.
Thanks for any help, and if I need to give more information for a good recommendation, just let me know.
fastman
4
I like my Synology's capabilities as it does everything I ask it to do. Although I can't testify as to everything you want it to do, I'd look up it features and see if it meets your needs.
Muse
40,868
10,222
Seems there are a whole lot of Synology NAS's to choose from. What do you have? I've seen offerings from them from ~$150 to ~$500, and I'm sure they expand beyond this range. I'm trying to get a handle on what I want/need/will be satisfied with. Seems like I could buy or assemble a network server machine, but that's more daunting than choosing an NAS, and maybe has more potential problems...
fastman
4
The basic DS213j is what I have and it works great with two 2Tb drives. Once they get old I'll up them to what ever is popular in the day.
cjp87
24
Thanks for the suggestions, but I ended up going with the Asustor AS-302T. Reviews were positive, and it apparently runs on the same SoC as the Synology DS214play. I also got a couple of 3TB WD Reds to fill it up. Comes in a couple of days, should be fun to play around with and get going!
fastman
4
What transfer speeds are you getting?
Did some quick transfers and looks to be anywhere from 30-36 MB/second but I remember a while back seeing it up to 50? Likely depends on the file size etc. This is with two WD Blacks FYI.
