Home insulation experts chime in
Howard
47,982
11
There's a room in my house directly above the garage which gets very cold in the winter. As you may have guessed, the "roof" of the garage is not insulated.
What's the proper way to insulate it? Obviously I need some type of insulation, but is moisture/vapor barrier necessary? How do I fasten the insulation to the... uh, I don't know if it's subfloor above the garage; I'd have to check.
drnickriviera
2,462
270
So is it an unfinished attic space? no drywall on the roof rafters? any decking or plywood on the floor? is it conditioned space (heated/cooled)?
Howard
47,982
11
No, the room is a bedroom so there is at least subfloor plywood. It is both heated and cooled, but too much energy is lost through to the garage.
Rastus
4,704
Blowing cellulose into the rafters (if you have them) is what is done mostly.
drnickriviera
2,462
270
Yep you need a vapor barrier. I think the easiest way is to remove the flooring and put in some kraft faced fiberglass. Some will say you don't need a barrier with blown cellulose, but i'd rather have one.
RU482
12,689
if there isn't already some insulation there, I've always heard that batt fiberglass>blown fiberglass>celulose
biggestmuff
8,201
Although it may seem like a good idea asking The Collective (ATOT) for advice, call a home insulation expert. I'd wait until early fall to get the quote and work done. People don't like working with insulation in hot spaces.
Greenman
22,315
6,476
If I understand what you're saying, the space you want to insulate is the floor system of the room over the garage. It should be drywalled on the garage side, as it's supposed to be a fire rated assembly. Blown insulation might or might not work, it all depends on how it's framed. I'd just pull down the drywall and insulate it, probably 15 sheets of board.
Greenman
22,315
6,476
Some of us are experts. :)
Howard
47,982
11
Ah, I'll take some pictures tomorrow. That would be the best way to explain it.
All the advice is well-appreciated, by the way.
amdskip
22,530
13
I'll second this. No sense ripping up the floor, much easier to insulate it from below.
desy
5,447
216
Vapour barrier goes on the warm side then the insulation. It keeps the warm moist air from inside the house from condensing and creating mold.
The spray foam is a good idea and the best way of doing it but not a DIY deal so probably more $ although I've never quoted it out
Greenman
22,315
6,476
Spray foam is very expensive.
Strk
10,197
4
Is it a finished garage or can you see the joists? If the latter, just get the thickest insulation you can get in there.
desy
5,447
216
You rip down the drywall get some 6 mil poly and acoustic seal , seal and staple that to the bottom of the floor fill the joist void with fiberglass bat insulation.
Drywall the ceiling again
bctbct
4,868
Vapor barrier, nice to install in new construction...not feasible for remodel
Just call an insulation company to come out and see if they can blow either fiberglass or cellulose into the void. Much cheaper and easier than pulling down the drywall. There is also a expandable foam but I think its pretty pricey.
RGN
6,623
+1, its not that hard and won't cost that much.
Analog
12,755
Vapor barriers are generally not done on ceilings, because the roof above the insulation is vented. Vapor barriers are for walls, which are not ventilated...
The ceiling of the garage should use 5/8" firestop sheetrock. The 5/8 firestop should also be between the living area and the garage.
I would then blow insulation over the garage area.
Edit: since it sounds like the room is directly over the garage, and there is no roof area as I originally thought, then a vapor barrier would be ideal.
flamingelephant
1,182
uhhh, one who doesn't use vapor barrier between a garage filled with carbon monoxide and their living space is an idiot!
flamingelephant
1,182
and you do put a vapor barrier over any ceiling even if the attic is vented... otherwise the warm moist air from the living space seeps through the ceiling, hits the cold insulation in the attic during the winter, condenses, turns into water, then leaks back into the house, or starts to mold, rot the framing in the attic etc....
Greenman
22,315
6,476
Both of your posts are incorrect. A garage should never be full of carbon monoxide. The idiot would be the person who runs his car in the garage with the door down.
A vapor barrier isn't always required, it depends on what climate zone you're in. Here in the Bay Area we don't use them at all.
