- Nov 28, 2001
- 22,205
- 43
- 91
So here is the issue. There are 2 rooms in question here. Room 1 has the cable modem and the router/AP. Room 2 has my computer. I don't want to use wireless because of the overhead. Currently I just use a long cable that snakes across the floor between the two rooms but this is ugly! What I want to do is feed this cable up through the attic and install Ethernet wall sockets that I can plug into that will connect the 2 rooms. Currently there is a power socket in each room which will be handy for using to find where I am in the attic and fishing the Ethernet cable up along. Now as for the Ethernet socket itself I see 2 options. Option 1 would be to cut another hole above the power socket and install a box there. The problem with this is how do I get around the power cable that's already there? Is there a convenient way of feeding this around the socket or through it or something? Option 2 would be to find a double wide socket and simply expand the hole where the current power outlet is and have the Ethernet socket next to it.
I've never done something like this before so any help would be appreciated. I have some experience with simple wiring of things like installing light fixtures and the like and I have crimped a few network cables so I think I can work out the Ethernet wiring from diagrams on the net.
Here is a pic of the basic idea I have.
If this works out there is the MUCH more difficult task of running Ethernet cable from the same room down 2 floors to the basement that I might look at doing.
Update:Wopee did it
I ended up having to put a small hole in the ceiling but it's not visible (will putty over it later). The layout of the attic was REALLY confusing so I drilled a small hole in the ceiling of my closet and threaded a coat hanger up into the attic so I could get my bearings. From there I measured off drilled through the top plates and fed all the wires. Looks much nicer with the actual cat5 plates on the walls
Update:Wopee did it
