home entertainment system
fluxquantum
2,398
i want to get a new home entertainment system for my HDTV. what brand will be give me the most bang for my buck? i can afford to spend 400 dollars max.
This has been moved to the OT forum.
AnandTech Moderator
Pariah
7,357
20
You need to define what you mean by entertainment center. What components are you looking for? If you can afford an HDTV, $400 for the rest of it sounds rather odd.
thomsbrain
18,148
do you mean a computer based system?
cause if you're just looking for speakers and amps, etc, this should be posted in Off Topic instead of hardware.
Muadib
18,124
912
Are you talking about a game console, like the PS2, Xbox and Gamecube?
fluxquantum
2,398
i am actually referring to a speaker system with subwoofer for my tv and dvd player. why is it odd that i can only spend 400? i don't see any problems with that. i just need advice and not criticism. thanks.
Pariah
7,357
20
It has nothing to do with criticism. Usually when you have a top notch video setup, you want to pair it with a top notch audio setup. You certainly cannot piece together an audio setup for $400. Basically you are stuck with one of those HT in a box setups you would get from BestBuy, and a lowend one at that. You're better off saving the money and spending it on something else.
Muadib
18,124
912
Geeze, take a chill pill dude. No one was being critical of you, just making an observation with the info given. The facts are that most people who spring for hdtv also want a good audio system to compliment it. $400 won't do it.
fluxquantum
2,398
well i don't want to spend a 1000 dollars. i don't have that much cash on me and probably won't for a long time. i just want something basic. by the way, the tv was a gift. i can't afford to pay too much for an entertainment system. just want to know some good brands.
ElFenix
102,402
8,572
might be better off just using the tv's sound than any $400 HT in a box getups. maybe you can get some refurbed stuff off of ubid or something.
Workin'
5,309
Just go to Best Buy or Circuit City (yuck) and get whatever "Home-Theater-In-A-Box" you can find that fits your budget. For $400 the brand ain't gonna matter, they will all be less than mediocre.
fluxquantum
2,398
well then what do you guys recommend? maybe i can scrounge up some more cash. if i do get a bonus check this year then maybe i can splurge on something more expensive. please provide links or product names. i am a novice at this stuff. what do you guys personally have?
tigerbait
5,155
Well since you have an HDTV, you're gonna want a progressive scan DVD player, and the best value model is the Panasonic RP-56, which is ~ $210. That doesn't leave much for a speakers and a receiver. Most people spend $200 on just the cables alone.
Workin'
5,309
<< Most people spend $200 on just the cables alone. >>
Not people with functioning brains or any real (as opposed to "marketing") knowledge of electricity and signal transmission ;) But let's try not to start a "magic wire" debate again.
I assumed you already had a DVD player. If you don't then plan on spending at least $200 for that in addition to whatever you were going to spend on audio gear.
John
Moderator Emeritus<br>Elite Member
4
<< well then what do you guys recommend? >>
I recommend you save another 1500.00+ dollars and then start asking for advice. ;)
I agree. I spent a good 600.00 on speaker wire and audio cables (component, toslink, coax, composite) for my new home theater system. I used Acoustic Research cables all around. High quality at a low price. Those "Monster Cables" (goertz, better cables, cat cables, etc) are all about price, not performance IMHO.
mboy
3,309
Nice gift by the way. I have decent HT system, but not the phat XBR yet :). I got a Harman Kardon DD surround system w/ HK surround speakers (5 + 75w powered 8" in sub which is PLENTY for my apt) for a total of less then $400 off of Ubid, but that was last yr amnd I dont see them having those speakers in a while. Right now I would recomend this: JVC complete home theater
My boss just ordered it for her Husband for $280 shipped. Fits into your budget right now. WHile of course not the greatest, it will provide very good sound for a great price while you save up for more sophisticated stuff in the future.
Right now, thats your best bet.
Yonux
90
well, I will say for 400$, just get whatever the best you can get at BB or CC kinda will be the same. I wasnt thinking about the best i could get and i bought the BOSE 901s and even though bose (no highs no lows),..... you do get what you pay for.
Yonux
ps I dont mean ti be critical but for 400$ they are all kinda the same,.. sorry.
Workin'
5,309
<< One word: BOSE >>
You're funny! That's the most overpriced stuff around. Just about the worst value for the money you could find.
Huma
1,301
people are right when they say $400 won't get you much, and within that price range, brand won't make much of a difference.
My receiver cost around $400 just by itself.
Just go to your local big brand electronics superstore and pick up whatever kit they have in your price range.
RanDum72
4,330
Hhmmm... $400 CAN get you somewhere with decent speakers. Polk R10's are $80 a pair at Circuit City so 4 is $160. The matching center (CS175i) is around $120-
140 so thats $300. You can get a KLH sub ( 10 incher with 120 watt amp) off Costco for $99. A Pioneer DD/DTS receiver (100w x 5) is $199, also at Costco.
Total is $600 +tax.
John
4
I think you meant two words: avoid BOSE
Dug
3,469
I second the Kenwood system. Sounds better than all of the other home-theater-in-a-box systems.
It's been recommended in all of the home theater magazines as what to get if you can't afford more.
MaryJo
13
$600.00 on Cables is just outrageous IMHO. Saving $$ any place I possibly can is my mantra. Found this place a way back that has amazing tweaks for your audio system.
Link
This link goes to instructions to make your own 75ohm digital cable - made mine for $8.50. :D
fluxquantum: Check out:
Link #2
It's a site devoted to "unbiased" audio reviews/info/etc for the typical home buyer.
