Home electrical outlet acting strange
TechAZ
1,188
I'm hoping someone can help me out on this before I call an electrician out.
Yesterday I plugged in my electrical shaver in the bathroom and it didn't work. No power and the lights on the shaver did not light up. I figured it just died since it didn't work in 2 different outlets and it is about 7 years old.
I buy a new one, it works in the outlet. Today my wife is going to plug in the hair clipper to cut my hair and that doesn't work either. I'm thinking "wtf?" so I try it in the kitchen and it works. I try my shaver that I thought died in the kitchen and that worked too.
Why would my new shaver work in the bathroom outlets, but nothing else?
96Firebird
5,737
334
Are they GFCI outlets? They should be, because I believe they are required in bathrooms, but figured I'd ask.
TechAZ
1,188
They are not. I'm renting this house and they are old school regular ones. Maybe I'll have to call the owner and let him know they need to be replaced then.
Vdubchaos
10,408
10
Flip the breaker at the electrical box (one of them will be to opposite side of the others).
KMc
1,149
I had an outlet on my porch that had the same intermittent problem. Even though all the wires to the back were connected tightly, there was some sort of short in it. Replaced it and all was fine.
TechAZ
1,188
When you say "intermittent", are you saying it would just sometimes work and sometimes not....or it would work with certain things and not others like what is happening to me.
96Firebird
5,737
334
Depending on when the house was built, and when the last remodel was, they may be legal. If the house was built after 1975, or the bathroom was remodeled since then, they should have been switched over to GFCI outlets. Either way, I'd request they be switched over just to avoid the risk.
TechAZ
1,188
Thanks. I will definitely do that since this house is only 16 years old.
Rvenger
Elite Member <br> Super Moderator <br> Video Cards
Apr 6, 2004
6,283
Mine is doing the same thing. The right plug works but the left one doesnt. I gotta change that here soon.
KMc
1,149
It would work fine with some things, but not others. I had two identical extension cords, for example, that simply would not work in that outlet even though they were fine in any other outlet. After I replaced the outlet, the problem went away.
Dec 19, 2003
32
I would start with the outlet like others have said. It can depend on the electrical load of the device as to why it works for some things and not others. Or heck, even the shape and size of the prongs of the device you plugged in can make the difference with worn outlets.
Rubycon
Madame President
Aug 10, 2005
17,768
485
It's old and tired.
Replace it with a quality (nylon face) receptacle. Do NOT use back wire connections, ALWAYS side wire them for best results. Loose grips cause intermittent connections and heating with heavy loads (like 1500W hair dryers hehe). Beware of aluminum (AL) wiring as well!
Since it's a rental your LL should be contacted and they should dispatch an electrician immediately to fix it. ;)
disappoint
10,132
382
First of all I have to recommend not working on mains unless you know what you are doing. Hire a licensed electrician.
Now that the above disclaimer is out of the way.
If you really feel comfortable fixing this yourself there are some things you should have. Like a non-contact AC voltage detector. I recommend the Fluke, but lots of brands will do fine.
https://www.google.com/#hl=en&safe=off&tbo=d&sclient=psy-ab&q=fluke+non-contact+ac+voltage+detector&oq=fluke+non&gs_l=hp.1.3.0l4.6296.8361.2.13100.8.3.5.0.2.0.52.143.3.3.0.les%3B..0.0...1c.1.qgZ1ulb2N4c&pbx=1&bav=on.2,or.r_gc.r_pw.r_cp.r_qf.&bvm=bv.1355534169,d.dmQ&fp=89c8db76974e7f67&bpcl=40096503&biw=1024&bih=545
Next up is an AC outlet tester like this one:
Those 2 and a good multimeter are must haves for AC mains work. Also some good electrician's pliers. You can find a lot of this stuff and a new outlet at hardware stores.
*Also it's fun to set your multimeter to ohms or diode test and connect it to live AC mains. If it's a Fluke 87 or equivalent December 21st 2012 will not be the end of the world for you.
*just for fun
BoomerD
65,719
14,132
Bathroom receptacles SHOULD be GCFI protected. While the outlet itself may not be a GCFI receptacle, there should be one "upstream" that's protecting the outlet. Look around. Odds are, you have one somewhere...and it's tripped.
Paul98
3,732
199
Turn off the power to the outlet pull it out see if all the connections look alright. If not fix that see if it works, and if that doesn't work I would just replace the outlet and see how that works.
nickbits
4,122
It's old and tired.
I always used the side screws until I moved into my new house here and noticed they were all back wired, so I thought that was preferred and started doing it that way. Guess I'll go back to side screwing them.
Rubycon
Madame President
Aug 10, 2005
17,768
485
Just think about it for a moment...
If you were an outlet and had no chance to avoid a screwing you'd rather take it in the side then in the back too! :eek:
