home CFD build - input needed (first build)
70m1
Hi all,
Looking to build a computer for running a CFD simulation (for my dissertation).
This will run under linux and is multi-threaded and very processor intensive. Once my dissertation is finished I will be looking to add a graphics card for gaming.
My budget is £600 (UK) And I am looking to buy from www.dabs.com (or anywhere else if deals are better)
I will be using it with a 1080p monitor, and I own a keyboard and mouse and won't use an optical drive.
Overclocking: I am not sure about this, I would like input on this please.
I will probably add a standard harddrive (and install windows) at a later date. for now 128gb is enough
Proposed system:
Processor:
i7-3770k: http://www.dabs.com/products/intel-core-i7-3770k-s1155-3-5ghz-8mb-7YXF.html
Ram: http://www.dabs.com/products/patrio...600mhz-viper-3-black-mamba-dimm-cl9-89TQ.html
Motherboard: http://www.dabs.com/products/gigabyte-z77-ds3h-s1155-intel-z77-ddr3-atx-8307.html
SSD HDD: http://www.dabs.com/products/sandis...ta-6gb-s-2-5--7mm-solid-state-drive-8HBN.html
PSU: http://www.dabs.com/products/best-value-alpine-700w-psu-120mm-red-fan-4-x-sata--pfc--78ZS.html
CASE: http://www.dabs.com/products/best-value-777-t-bird-blue-gaming-case--no-psu--7W6P.html
Any input on this? Any tips? Thanks, all help appreciated.
Tom
So your CFD programs do not benefit from a GPU for visualization? I have not done any CFD work since school, but it seems like there might be a benefit there. If multi-core is more important than single thread speed you could go with an AMD solution, just a thought to save a few pounds.
Hi thanks for the reply, single thread performance is important. If you run the simulation not in parallel you get allot more information about what the simulation is doing so I will be doing that (occasionally). Also I will be pre and post processing without a gui so the graphics chip will be largely redundant.
Can your CFD software benefit from the computational ability of a GPU? How long does it take to perform a run? If you aren't running multi threaded at all, you can look at the i5-3570k instead to save a few dollars, as it's very similar to the i7-3770k except it does not have hyperthreading.
Sorry I wasn't very clear with my reply. Some times I will run on a single processor for a few hours, perhaps a night. But the full simulation run will be on as many cores as I can get for a few days to a week. Hyperthreading apparently works very well here. And pre- processing is also single core work.
OpenFOAM (the CFD package) does have the option to use the GPU for compute, but from the research I looked at 3 *Tesla GPU is only slightly faster then an i7 extreme. GPU compute only comes into its own with extremely complex meshes I believe.
It appears that you can get some of your components for less at Aria PC.
Overclocking will require aftermarket cooling. I am not sure if it is appropriate for your use scenario, so I can't help answer that question.
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: Intel Core i7-3770K 3.5GHz Quad-Core Processor (£239.99 @ Aria PC)
Motherboard:
Gigabyte GA-Z77-DS3H ATX LGA1155 Motherboard (£67.99 @ Aria PC)
Memory: Patriot Viper 3 16GB (4 x 4GB) DDR3-1600 Memory (£69.50 @ Dabs)
Storage: Sandisk Ultra Plus 128GB 2.5" Solid State Disk (£69.96 @ Amazon UK)
Power Supply: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply (£48.17 @ Aria PC)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer (£12.85 @ Aria PC)
Total: £508.46 (Prices include shipping, taxes, and discounts when available.) (Generated by PCPartPicker 2013-03-06 17:59 GMT+0000)
Add your case total to this since the case is not in their database.
Motherboard:
This looks good to me. The one change that I would make is to drop the CPU down to the i5 3570K because OpenFOAM, like most CFD codes, does not benefit from hyperthreading. You'll actually get 2-3% lower performance with it enabled.
Thanks for the input. That PCPartPicker website is gold!
Looking forward to building this now.
