I don't know if many of you know or it may not be the same in your area.....but I live outside Fort Worth and needed to get an additional IP for home. Well I called and ordered, the tech asked if I was aware of the 6.95 additional cost. I said yes, I know. I then asked him if my bandwidth would be split between the two IP and he said no, the max speed is based on IP, just run the cable modem to the hub and run the 2 pc from the hub. He said the modem could handle up to 10 IP's without degradation of speed. I was shocked! He said most people run a proxy which would split the bandwidth and said that was stupid when you could get a second IP for so cheap and have the same (higher) speed on both the machines (you can get up to 5 for home use). This is great for me....I run an ftp and website from my main box. And when I am at work I could never get in because of all the leeches hitting me. This is why I got the second IP. I am using netBEUI for my home network and mapped a drive to the other machine so I can hit my main machine from the second IP. Works great.........Just an FYI
