- Jan 9, 2007
- 314
- 0
- 0
I am not sure if I should be posting this here or in the A/V forum, but I am interested in playing around with building a speaker from scratch. I wanted to try something small, using materials easily (see: cheaply) obtained: I was planning on using a canning-jar lid (regular width, meaning about 65mm) for the frame, sandwich bags for the diaphragm material, and some neodymium magnets from a local electronics supply store.
There appears to be very little on the web about this topic (or I am just asking google the wrong questions), but most of what I've seen is low-sensitivity speakers built using cardboard and iron magnets. My plan was to extend these projects to a smaller design, using a more flexible material, and a stronger magnet.
The intended use is for un-amped speakers/headphone speakers. And, while I am doing this primarily for fun, I would enjoy having something useful at the end. Hence, I am willing to get Obsessive-Compulsive about the quality, all else being equal.
Here are the questions:
0. Can anyone recommend to me a project or thread that dealt with this already, or a resource for this kind of information (bear in mind, I am no EE).
1. Would the plastic in sandwich bags deform too easily to be used as a diaphragm? And, if so, what would be a better material be, that could be still be obtained easily?
1.b How do variables like diaphragm weight, size, flexibility, tightness, etc. affect frequency response from the finished speaker?
1.c I am not really using a spider, but I am using silicone caulking to secure the diaphragm. For this small of a size, and considering the material, would one be necessary?
2. Am I right in assuming that more wire-length/higher magnet power makes for better SPL with a given diaphragm material at a given voltage?
3. for the coil, does the total mass of copper have an affect, or is it just about the un-wound length? What strength magnets do typical headphone speakers use?
4. Is it necessary to have an axially polarized magnet?
