- Jun 30, 2012
- 7,306
- 5
- 0
Hey AT Garage. Been a while since I've been here. I got aggravated by ATOT and quit posting...I dunno, a couple years ago? I forgot my login info and email had changed, so I had registered a new account a little while ago. Hopefully that's okay and we can just leave this little intro at that.
I wanted to post and see if anyone else has ever tried to build their own device for 'smoking' vehicle intake and evap systems. I've recently quit working for the stealerships, and I think I'll find some success on my own. But sometimes you REALLY miss having a particular tool, especially when that tool is ~$1000 or more to buy new.
The commercial smoke machines I've used always has some kind of propriety solution stored in them, and you'd simply hook a couple leads up to the battery, and hit a pushbutton. Smoke would roll out of the attached vacuum hose fairly quickly. Most of them simply consist of a glow plug (like in a diesel) or similar heating element, somewhere for the smoke to acculate, and something to push the smoke through the hose and into the the area you're leak testing.
Google found a lot of discussion and a few working examples, which I used, together with my own intuition and whatever crap I had lying around, to build my own smoke generator. I'm almost ready to start testing...and then, surely, tweaking my design.
Anyhow, behold my ghetto masterpiece. Ignore the destroyed carpet and dirty room, please...there's a reason I do these things in the ugliest room in the house. And it stays ugly.
This is the remote. It is carefully fabricated from some cheap radioshack switches, some wire, a couple bolts, and tape. Classy, right?
The commercial units have a single pushbutton, like a remote starter (of the diagnostic variety). AFAIK, this immediately turns on both the heating element and whatever the machine uses to move air. Since I have no idea how either of these things will perform, I'm using two seperate switches. One is momentary, the other toggles.
And it leads down about ten feet of wire to this stuff. This is so I can move around while continuing to pump smoke as needed (since evap leaks can be at either end of the vehicle). Also, this is important because most 'home-built'/DIY machines simply use switches or valves to turn on the air supply and heating element. I don't believe I want either to run constantly.
Glow plugs get over 1000*F. You don't want to just...leave that on. And you don't want to build significant pressure inside of the vessel holding hot mineral oil (or some kind of glycol solution...whatever makes the best smoke without being bad for the vehicle- havn't decided).
The glow plug is in the bottom of that paint can, so I can control how much of the liquid is covering the the heating element. Fitting in top is the smoke outlet, the one in the side is the air inlet. Those air hose fittings are kind of placeholders until i test this and see how hot it gets. Also I'll seal them up around the base with some high-temp epoxy.
The cables at the top would go to battery. Yes, the negative is a pair of ~12g speaker wire using all the copper for the same function. Positive is 8ga from an old car audio install. With a fuse, of course.
The negative goes straight to a clamp that fits snugly on the body of the glow plug (that whole can will be a ground). Another small wire ground the relay coil. The positive goes to the high side input of the relay, with the output having a spade terminal for the glow plug. It also has a small wire that leads to the switch, which will trigger power for the relay coil.
The other switch leads to that molex connector, which connects to my modified portable compressor. I could've just used the little compressor bit, but I figured I'd keep it together and just tap into the on/off switch.
There's also a computer PSU I may put with all this so that I can plug it into a wall, instead of using the car battery.
Total investment right now is like...20 bucks, maybe. I bought the relay and the glow plug.
Yes, this will need testing and tweaks. That will be tomorrow.
Hey, it beats paying a grand to have someone essentially engineer the same device and put everything in a pretty case.
edit- Oh, and nothing is 'done.' Bare connectors need to be covered, everything should be on a sturdy base, ect.
