crockman
This is My Very First Build' so I a-bit overwhelmed
I've put together this PC from Used Parts. All the Parts were very cheap so Hardware-Problems may be at fault ???
I chose to Buy cheaper (outdated) parts so if I screw-up i wont be wasting a lot of Dollars$ on this 'Learning' Experience.
To fill you in: Mobo-Asus A7V8X-X, Athlon 1.333gig (266fsb), 512MB DDR400, WD20g HD, Gainward GF3 64MB Ti200 "Golden Sample" AGP Card, LiteOn CDRW, Samsung DVDRom, Floppy Drive
The Computer Starts & I can get into BIOS. (I Do hear 1-Beep)
I then, in BIOS, set the PC to Boot first from the DVDRom (CDRW is not yet connected).
I inserted my XP-Pro Sp2 CD & Rebooted.
I easily got to the point where it asks "If you want to set up Windows hit enter"
I chose to Format the Entire 20gig HD in 1-partition using the NTFS (Not the Quick Format)
The PC Formats the HD Etc, Etc, Etc.
I keep getting to the point, When All the Files are Done being Copied you get the message "The Computer will restart in 15 seconds"
When the PC restarts the Windows installation does not continue.
If I start the PC; Booting with the XP-Pro CD, the 20gig Partition is now there, but theres No way to get the HDD to Boot
My XP-Pro CD is a "Dell Reinstallation CD". This CD is known to work on Non-Dell systems. Maybe it doesn't work on My particular Set-up, dunno ??? Or Maybe MY HDD is Bad ???
I also have a Brand New Windows 98SE (for PCs' without Windows). But I do Not know how to install 98SE, I only have experience installing XP.
I'd rather install the XP-Pro, but if I can't, Can anybody Help install the 98SE ???
I've already been to bootdisk.com & Downloaded a Windows ME Bootdisk. But i don't know if i loaded it onto the Floppy properly. I've tried booting this Homebuild from the ME-Bootdisk, I then get the Message " Remove Disks, or other Media" "Hit ant key to restart". Nothing Happens.
So Basically I'm Lost, Can anyone Help
Thanks
Thanks
