So this is my brand new Venice rig:
DFI nForce4 Ultra-D
Venice 3000+ LBBLE 0517 APAW
2x512MB TwinMOS CH-5
Right now I'm at isolating the CPU phase. I have tested my HTT and it crapped out around 300 at default voltage. So right now the CPU is running on 1.5 vcore, 280x9 (~2520MHz), and it's at freaking 70C!!! I know it's probably the MB sensor reporting high.. but it's good to make sure so I don't freak out later
Why the hell is it so damn hot? I know that my XP-90 + 92mm Panaflo L is properly seated because it feels hot to the touch. BTW the chipset temp is 48C.. which is barely hotter when idle.. where do I check ambient case temp?
The other funny thing is.. it jumps from about 47C idle to 60+C in merely seconds right after I turn on prime95 small FFT torture test.. and when I stop the test, it returns to idle temp just about as fast 😕 So far it's been running prime95 for about 1/2 hour.. and I think I still can push it a bit more.
I think I have one hell of a chip here.. but it's just too dang hot :/
Update: Lowered vcore to 1.45v and increased HTT to 290 (I know, I know), still going strong on prime95 😀 It's now going 65C max.
DFI nForce4 Ultra-D
