Holy Subwoofer!
I remember that episode, love that show 😀 I love the kid's face 3:26 into it lol.
I'd like to see the driver play this.
I say see because there would be nothing to hear - unless it was really pushed.
I really doubt its motor is rated at 8 continuous horsepower. :Q
hair trick
http://www.youtube.com/watch?v=-fdiajaVrT0
http://video.google.com/videoplay?docid=-7885139890934147401
fan based subwoofer
http://www.ohgizmo.com/2005/10/31/worlds-most-powerful-subwoofer/
World?s Most Powerful Subwoofer!
Super SubwooferBy Josh Ray.
No, it?s not a fan. That, ladies and gentlemen, is the world?s most powerful subwoofer: the Eminent Tech TRW 17. Rather than your garden variety 10 or 12 inch paper cone pulsating back and forth, this subwoofer creates a wall of air as big as your living room. In other words, the entire room becomes a resonating box!
By rotating the fins and modulating the speed, frequency goes all the way down to 1Hz, the territory of jet engines, nuclear explosions and plate tectonics. By comparison, your typical sub hits 20Hz on its best day.
With a price of $12,900, the TRW 17 is for rap superstars only. Rumor has it smaller versions are in the works as well as one model specifically for cars ? naturally, you must present your rap superstar ID at time of purchase.
Originally posted by: 0roo0roo
hair trick
fan based subwoofer
Ugh the hair trick. Well duh anyone's hair will do that if someone is dumb enough to put their head in the vent of a large box. That's all those car systems are is a speaker box with seats. (insert Martin Lawrence words about dick going down the road with two balls side by side! :laugh: ) Either way horrid bass quality, far from the actual performance but if people want it to shake their nuts that kind of sums it up about the typical male preoccupation with size now. 😉
The rotary woofer design is ok but already outclassed and (soon to be!) obsolete. It makes noise on its own which a lot of people are upset over. The price isn't a factor as most obsessed audiophiles put worries about cost in last place. In the video posted you can see the motor moving on its mounts. That is very bad - it clearly needs to be braced better. This is the equivalent of an inadequately braced conventional speaker box. Emissions from flexing panels are out of phase with the diaphragm or in this case the movement is probably reducing output at the lowest levels where it would be most needed. At single digit frequencies distortion is going to be hard to hear unless it is at the half century mark. :Q
Didnt you guys see the Mythbusters episode where they built the monstrous subwoofer in this old car. It hit over 160 decibels before it came apart......
That's a noise maker not an instrument for re-creating a wave. 😉
If I wanted to make something LOUD and blow up - a small charge inside a barrel of flour inside the vehicle would be nice. Flash boom to expand the dust and then kaboom! Should easily be 185dB+ inside just before the pillars collapse and the windows push out. A few streak cameras running at 5000 fps to capture it would be fun. 😀
I'm sure CHP would be willing to donate a ricer impound for good cause.
meh. i prefer accurate, tight base response over heart thumping, bone jarring base. I think I'll stick with my JL Audio 10w7
