Ho do I Copy an MP3 to a cassette tape?
YosemiteSam
114
OK, I know this probably sounds dumb (I'm a newbie when it comes to these things),
But I want to copy some MP3's to a cassette tape. How do I do it?
Thanks.
madthumbs
Banned
Oct 1, 2000
2,680
Use the output from your sound card and plug it into the input of a tape recorder. Then play and record.
Workin'
5,309
Use the LINE out (not the speaker out) from your sound card, if it is so equipped.
Cosmic_Horror
1,500
you can always burn them to a cd (as wav files) and then record them to tape as you would normaly. :)
Dan
I do the same as Cosmic_Horror. That way I have the best of both worlds.
