Hmm..... What's the worst way to die?
Zeeky Boogy Doog
2,295
having half of your body burning, while having the other half suffering from intense frostbite after having your balls slowly nibbled off by rats all after weeks of starving and having your legs being eaten by gangreen and during it all you have a long lasting case of constipation and also, there is a snake in your stomach slowly eating its way out
Rip the Jacker
5,415
Slapping A Lion In The Face (that is if you don't die reaching him) and being eaten apart?
Getting eaten up by pirahnas?
Getting buried alive...?
Various torture methods.. Too lazy to think of them.
btw... http://www.ogrish.com if you really want to know some methods.
Rock Hydra
6,466
I would probably say an Aneurysm. Even though in most cases the pain doesn't last more than about 10 seconds, I would probably guess it's the most intense headache immaginable. Like your head is blowing up like a baloon and is about to explode or something like that.
piroroadkill
731
We created the definitive answer to this a while back on SA. I can't be bothered to find it now.
Someone will always one up you, pointless thread.
DaWhim
12,985
the chinese history on execution. you will find the worst possible way to die.
ever herad of thousand cut? the guy that cut you will make sure you will have a thousand cut in your body before you die or he will be executed too. the last cut is your throat.
the other one is dig you in the ground and open a little hole in your head, then put mecury in it. I just have my lunch, I am not getting into the detail.
glenn1
25,383
1,013
Decompression sickness (the bends). Basically all the cells making up your body are swelled and then "popped" by expansion of nitrogen bubbles. Your joints and nerve cells are the first to go and needless to say the pain is excruciating.
