Hmm...subwoofer problem: the speaker part detached from the ring or the metal part....
chiwawa626
12,013
Ive been driving my dads 1992 ls400 for a week and i guess nobody uses the radio much , or with much bass...well theres a subwoofer that came with the car its in teh rear near the break light (behind passengers heads) and it started to make a funny noise...i checked it out, looks like the speaker part, paper stuff, detached from the ring or the metal part u know the outer area....how can i fix this!?!? it hecka vibrates and makes a funny noise...
ThisIsMatt
Banned
Aug 4, 2000
11,820
Get a new one. You can try to glue it, but....get a new one.
chiwawa626
12,013
I looked around online and found they sell kits for what happen to myne, they sell foam/cloth/rubber rings to replace the ones that broke...i saw one on ebay for 8 buackaroos...ill look around...mabey ill just get the kit, i dont think id by a new speaker just for this thouhg..
Heisenberg
10,621
A new one is your best/cheapest bet. I don't think they can even really be repaired anymore when the surround goes.
Edit: Didn't realize they sold kits to replace the surround. Still, unless you aren't concerned about sound quality, I'd replace it. I doubt the kit will give the same quality as the original
Shockwave
Banned
Sep 16, 2000
9,059
If its just the surround coming loose, you can glue it and shouldnt notice a difference. The surround doesnt play a major part in the SQ of the sub, not as much as say the motor structure. The surround simply helps control the cone during movement, and allows a seal between the front and back of the cone. Think of it as a suspension part. I've heard of people glueing them with good results, but you can try a repair kit or replace it too. Try
Sounddomain
or
Car Audio ForumsSounddomain
