Ok, this is driving me a little batty. Kid complained today that she was off the Internet. Checked it out and the wireless was disconnected. Tried to refresh and didn't see the network, so I restarted. After restart was able to see the network and connect. Adapter shows connected, signal strength low.
Thing is, DHCP works fine. IPCONFIG shows the correct local address, DHCP server, DNS server, etc. Release and renew works. But the machine can't connect to any of the others on the home network, can't see their names, and can't ping them by IP. It also can't ping the router by IP. Other clients also cannot see her machine by name or IP. I've tried it with windows firewall on and off.
Anything else worth checking?
She's running Windows XP SP2. None of the other systems on the network (5) are having problems. Router is up. All other systems can see and ping each other, but not hers.
I can't figure out why release/renew would work, but I can't get a TCP/IP connection. The adapter shows healthy and connected, with traffic. Protocols are all in and correctly configured.
