Originally posted by: flyboy84
I remember people having those problems with HL2 on any machine regardless of spec when it first came out. did you update the game through steam?
we have this threads every once in a while.
HL2/Source engine has those problems *ever since*...its extremely sensitive to things like a properly defragged HD.....the hitches come mainly from loading sound-files. Means. the first time a sound is loaded until it's cached.
Even on my sys i get those hitches once in a while...the ONLY thing you can TRY is kinda involved...this is rebuilding the soundcaches for the whole HL2
http://developer.valvesoftware.com/wiki/Soundcache
This explains how to rebuild soundcaches in HL2 - which might help too.
Edit: Skip that "crate maplist.txt"...the game already has one - so the above does basically go thru each level, loads the map, pre-loads the sounds and generates new cache files. (Well, yeah, kinda advanced stuff...but i find it's interesting)
HOWEVER, under normal circumstances you should NOT have significant problems if your HD is defragged and you have plenty ram....EXCEPT every first time when something gets loaded from HD
Otherwise, you might havr to live with the minor hitches.....know at least they should only appear the first time when something's loaded and then not anymore. (???) SOurce-engne is good, fast, but not perfect....
EDIT: i posted all that already in this thread earlier....didnt realize it's the same thread
