UECWeb has a super deal on this DLP HDTV monitor. It also includes a matching stand, a spare lamp, and one year factory warranty. White glove delivery is about $200.
UECWeb typically sell refurbished Hitachi products. But this one appears to be new as it carries a one-year warranty as opposed to the 30-day one that comes with refurbished products.
Description:
2002 Model: Reg. $7,999.95 + $500 value matching Stand and a $200 Lamp
55" 16:9 Widescreen DLP HDTV Monitor/NTSC Projection Television with One Year Factory Warranty (The warranty card is included with the unit.)
720p HDTV Monitor
Exclusive D Digital Display Driver with 3-2 Film Correction
Progressive Scan 720p with 480/480p, 720p/1080i Input Signal
Digital Light Processing Technology
1280 x 720 Display Resolution
Brightness: 350 cd/m2
16:9 Aspect Ratio
Exclusive Hitachi 10 Element Lens System
Exclusive Hitachi 6 Segment Color Wheel
PC Display (XGA Compatible)
Digital 3D Y/C Comb Filter
Digital A.I. (Movie/Sports/TV)
First Surface Mirror
Four Screen Fill Modes:
Normal: 4:3 Original Aspect Ratio
Full: 16:9 Original Aspect Ratio
Fill: 4:3 Zoom
Smooth Wide: 4:3 Expanded
Fine Pitch Diffusion Screen
Sound
MTS Stereo/SAP with dbx
Dolby Digital 5.1 , Dolby 3, Stereo and Pro Logic Surround Sound
60-Watt 2-Way Bass-Reflex Speaker System
Center Channel Speaker
5-Band Graphic EQ
Dynamic Bass
Perfect Volume
Loudness
Automatic Noise Cancellation
Subwoofer Control
Convenience Features
Digital Window Plus
Dual Tuner Picture-Outside-Picture
Dual View Split Screen
MultiViewer 3 Auto Channel Surf
Illuminated Thumbstick Universal Remote
Through-the-Screen IR Sensor
Three Language On-Screen Display
181-Channel Tuner with Auto Programming
Plug & Play Interactive Set-UP
Auto Link
On-Screen Help
Front-Panel Menu Controls
Family Favorites (Favorite Channel)
Power Resume
Parental Control
Channel Lock/Video Lock/Quick Lock
TV Time Out
Front-Panel Lock Out
TV/Movie Rating
2-Level Mute
Channel ID/Video ID
4-Event On/Off Channel Timer
Sleep Time (15 to 180 minutes)
Closed Caption Decoder (CC)
Commercial Skip
Discrete IR On/Off and Input Codes
Inputs and Outputs
A/V Inputs (Rear/Front)???????????2/1
S-Video Inputs (Rear/Front)?????????2/1
Wideband Component Video Inputs??????.2
(1080i/720p/540p/480p/480i)
RGB/PC Input (15 Pin D-Sub) (R/F)?????..1/1
R/F Inputs?????????????????..2
Monitor Out with S-Video???..???????..1
Optical/Digital Audio Input????..??????.1
Surround Speaker Terminals??????...?..L/R
Sub-Woofer Output?????????????..1
Multi-Scanning?31.48-79.98kHz(h), 56.25-85Hz(v)
Plug & Play??????..VESA DDC28 compliant
Specifications
Color??????????...?...Silver/Gray
Dimensions (inches)
Height??????????.????.40
Width????????????....51-1/2
Depth??????????..?..?23-3/4
Weight (lbs)?????????????202
Power Consumption (watts/amps)?...440/4.0
[Alert Moderators]
[Flag As Dead Deal]
Description:
720p HDTV Monitor
16:9 Aspect Ratio
Fill: 4:3 Zoom
Sound
5-Band Graphic EQ
Dynamic Bass
Perfect Volume
Loudness
Subwoofer Control
Digital Window Plus
Auto Link
On-Screen Help
Power Resume
Parental Control
TV Time Out
TV/Movie Rating
2-Level Mute
Channel ID/Video ID
Commercial Skip
Inputs and Outputs
Specifications
Dimensions (inches)
[Alert Moderators]
[Flag As Dead Deal]
