confusingcomputers
Hey guys, the last couple of days, i finally dove into the wild world of overclocking. I was busy all of last year when i bought my computer since i attend medical school, but i bought bf2 this summer and figured i would try to squeeze a bit extra out of my system.
First i'll give you my specs.
Asus a8v
4 512MB corsair pc3200 sticks of ram
geforce 6600GT
amd 3000+ winchester
OK, so i have messed around a bit with all the common overclocking variables and i've hit a wall at 2177 MHZ and 242 FSB with 1.6 volts of power. I have the memory set for DDR 333 so my memory is running at 198 MHZ at this same 242 FSB. I also had the mobo HT transfer at the default 1000 mhz (5x) at the time, but after some research found that this actually caused my speed to be way overclocked to 1210 mhz
I wanted to get my memory to a slight overclock, around 205-210, with a about a 2.3 ghz processor OC, but my processor seems to be holding me back. I increased the voltage to 1.7 and tried raising the FSB to 248, but my computer freezes during the windows loading. (it was stable for a while with 245 FSB and 1.6 volts of power, but then frooze).
It is also stable for 3 hours using prime 95 for the 242 FSB set up (while i watched Wedding Crashers, good movie). This was with the mobo speed of 1210 mhz i mentioned earlier (at the time i didn't realize this was another variable that could be tweaked). So i thought the HT on the motherboard (this is the part i really don't understand) may be causing my problem. So i lowered it from 1000 (5x) to 800 (4x) wich given my fsb of 248 shold have given me a HT of 992. HOwever, i get the same results when i increase my voltage to 1.7 and FSB to 248. Also, if i leave the voltage at 1.6 and up the FSB to 248, same results.
Oh yeah, my temps were good too. i was at 46^C after the 3 hour test.
So, i was hoping some of you savy old verterns at OCing could provide some insight for me. Whats the deal? I have reached the boundry of my rookie ablities. I need some assistance. You think the point i am at now is a good OC? The only part that bothers me is that my ram is actually underclocked at 198mhz.
On a side note, i did decrease the FSB to 220 and set my ram to a 1:1 ratio so it would run at 220mhz to see if my ram was the problem, but everything ran fine that way.
Thanks in advance, sorry for the long post.
Asus a8v
geforce 6600GT
