HIS ATI Radeon X1600PRO
Steve
15,945
www.chicagopipeband.com
I have a feeling that your AGP driver (part of your chipset drivers) is missing or corrupt. Reinstall it, or the whole chipset driver package if you have to. Ideally it should be installed first before the video card drivers, so you may want to consider uninstalling those before reinstalling the AGP/chipset package.
Fred Rogers
63
nope...im in Santa Maria. but my BIOS settings are set to AGP/Onboard. the only other setting for that is PCI. its a store bought comp..so there arent many options to choose from.
Fred Rogers
63
k.. i got it to go back into 8X mode...but now its doing the freezing thing again..what should i do now. ive tried the latest chipset drivers. they freeze it up, im trying some older ones now..since my board is a little bit old. if you have ne suggestions that would be great.
dclive
5,626
BIOS 3.15?
KM400a isn't exactly old - it's mid-2004 timeframe. Is 2 years "old" now? Sigh...
You've attached a power cable from your PC to the graphics card?
Fred Rogers
63
yes. ive got the latest drivers from ATI, ive tried the latest chipset drivers, they just freeze the whole computer, i have the latest BIOS for my board. im using some chipset drivers that dont even support AGP..so i can use my card. basicly ATI screwed me....or my computer is gay.
Fred Rogers
63
I downloaded the Version 5.09A Chipset drivers and my motherboard is:
Motherboard specifications table
Motherboard Part / Feature Specification / Support
Motherboard Description Mb manufacturer name: ASUS A7V8X-LA
HP/Compaq name: Kelut-GL6E
CPU Socket A
AMD Athlon XP
Core frequency up to Athlon XP 3200+
Chipset VIA KM400A
VIA VT8237
Front Side Bus (FSB) 400 / 333 / 266 MHz
Memory 2 x 184-pin DDR DIMM sockets
Support up to maximum 2 GB memory (PC manufacturer's maximum memory may differ)
Supports unbuffered PC2700/2100 non-ECC DDR SDRAM memory
Expansion Slots Three PCI slots
One AGP 8x/4x (1.5V)
Storage Two UltraDMA 100 IDE connectors
Two Serial ATA connectors
Integrated Graphics VIA UniChrome graphics
Audio Realtek AL658 six-channel AUDIO CODEC
Digital audio via an S/PDIF out interface
LAN Southbridge integrated 10/100 Mbps
VT6103 LAN PHY
Hardware Monitoring Super I/O integrated monitoring of: CPU/chassis fan, MB/CPU temperature
Rear Panel I/O Ports One Parallel
One Serial
One PS/2 Keyboard
One PS/2 Mouse
One RJ45 port
One Audio I/O
One VGA
One IEEE 1394
Four USB 2.0/1.1 (Two connectors)
Internal I/O Two USB connectors support additional four USB 2.0 ports
One IEEE 1394 connector for an additional IEEE 1394 port
CPU/chassis fan connectors
20-pin ATX power connector
Front panel connector
CD/AUX connectors
Front panel audio connector
BIOS Features 4Mb Flash ROM
Award BIOS
Enhanced ACPI
DMI 2.0
Green features
PnP features
Industry Standard PCI 2.2
USB 2.0/1.1
Manageability WOL
WOR
Wake on PS/2 mouse
Support CD Contents Device drivers
ASUS PC Probe
ASUS Screensaver
Award BIOS Flash Utility
Adobe Acrobat Reader
Trend Micro PC-cillin 2002
Form Factor Micro-ATX form factor: 9.6 inches x 9.6 inches (24.38 cm x 24.38 cm)
Fred Rogers
63
it cant be disabled,,..because the only options in the BIOS is to use 1. AGP/Onboard 2. PCI...those are the only two options in there. and yes i have used driver cleaner pro to clean the drivers off.
Steve
15,945
Okay, see if it is listed in Device Manager. If it is, right-click on it and choose Disable. If it's not, or it is but shows as Video (VGA) Controller, try this: install the IGP's video driver (seriously), then go into Display Properties, right-click on its monitor and uncheck Attached. You may or may not have to disable it in Device Manager as well.
Good luck! I'm off to California in the morning for five days. I hope this gets resolved.
Steve
15,945
Quit banging your head against the wall, dude. Uninstall all video card and chipset drivers in Safe Mode, run Driver Cleaner Pro and clean out all lingering files and reg entries for the vid card, reboot, don't let them reinstall automatically. Instead reinstall them manually - chipset drivers first (including the AGP driver), then reboot, then the video card drivers. Make sure you've got the proper drivers for your chipset as listed here:
http://www.viaarena.com/default.aspx?PageID=420&OSID=1&CatID=1070
If that doesn't work, I'd be inclined to reformat/reinstall but that is up to you. If that didn't fix it, there are larger problems present.
