Ok, while I already have a guess on what the answer is to this question, I am not
hundred percent sure so I will ask.
Right now I have a HighPoint RocketRAID 404 in my system. I had
the system raided up but I lost a drive so as of now its just got
one hard drive connected to it.
Now I am thinking of getting a DVD burner for my system. However
all my IDE controllers from the motherboard are used.
Now I have read that the HP Rocket 133 ATA Controllers only support
hard drives and not ATAPI drives. Now I am just guessing here but
I'll take that to mean I also cannot throw a DVD burner on the RocketRaid.
Is it correct to guess that?
Also if I have to buy an IDE controller card to support an extra ATAPI drive,
which would you suggest. I notice some say they have support for it. Others
say nothing, and yet others say they don't support ATAPI drives.
I would appreciate any help you might provide.
Edit Oh and a quick afterthought, what about SATA Controllers, are there any of those
that might support ATAPI as well.
