- Aug 5, 2008
- 46
- 0
- 0
So I went to someone's home to fix their computer because their mouse and keyboard weren't working. I thought this was going to be easy. I first bootup the computer and it goes into windows and sure enough the keyboard and mouse do not work at all. I have to force shutdown.
It's a USB keyboard and a wireless mouse on a USB receiver. Note: the computer only has USB ports, no PS/2 ports (Dell).
I open the computer and pop the CMOS battery out and put it back in thinking BIOS is having an issue setting up components so I reset them this way. Now I turn on the machine and it says Keyboard failure, something about Floppy seek failure and low voltage on CMOS battery. Then it says press F1 to continue or F2 for setup. Now usually we all know that even when it says this the keyboard still works, but not in this case (I tried plugging the keyboard and mouse into a different computer and they work just fine).
I goto the store and pickup a new CMOS battery and a PCI card with USB ports on it. Put them both in and still same issues. Keyboard is now on the PCI USB ports and still won't work. I tried all the USB ports on the computer and restarted every time. I thought maybe the front ports will work and only some of the back USB ports fried, but nothing. I can't pass BIOS to get into Windows even.
I suspect this is a motherboard issue but I welcome any opinions.
Thank you.
Thank you.
