Highest Voltage for Northwood P4?
pookguy88
1,426
What's the highest voltage a P4 should be upped to.
I want to be able to have a stable system, that will last at least 5 years...
so i know upping the voltage will decrease system life but... is 1.7 a good upper limit?
i know some people go up to like 1.85 but is that a bit much?
ChampionAtTufshop
2,667
yes 1.7v actual in windows is a good limit
you could probably get away with 1.725-1.75v wtih some really good cooling, but i would determine whether to use the extra .025 or .05v depending on the amount of overclock it gets me
remember temperature doesnt kill the northwoods, its the voltage
phamtastik
711
I ran a 1.8a @ 2.7ghz...... voltage 2.1 or 2.05..... died in a month =)
Ran my other 1.8a @ 2.4 voltage 1.72 for a year fine...
On vapochill setup though.. idle was 4 degrees C
Trying to hit 3 Gigahetz with this 2.0a... with a 1.8V
THUGSROOK
11,847
1.7v max.
but what ppl need to realize is that the difference between 1.675v and 1.70v is only 1 fsb tops!
