Highest VCORE setting on KK266
I want to increase the vcore voltage for better stability(1G TB OCed to 1.33g) on my KK266 mobo.
I saw the highest setting in the bios is 1.85. Is there anyway to set it higher?
All reply is appreicated.
i don't think so...at least not without physical modification to the motherboard itself. i think the 8k7a is the only mobo that will go higher. it sacrafices fine tuning for high voltage (+.1 increments). however, i guess i'm not positive about the kk266 though...
If you set to 1.85V and check the monitor reading you should see that it is in fact well over 1.9V. On my KK266, it reads as high as 1.97V.
