Question Highest CFM Fans at 120mm and 140mm
UsandThem
16,068
7,382
That's about what they top out at in those sizes.
You do know they will sound like a vacuum cleaner running right? Noctua (Industrial line) has fans that are similar in CFM performance to the ones you already found, and they output 41+ dBA. The "Ultra Strong" one above is rated at 59 dBA, while I didn't see a noise rating for the Bgears model.
https://noctua.at/en/products/fan/industrial
You might already know about the noise aspect and that's what you want, but I just wanted to point out the noise these things will output.
piokos
554
206
86
I am looking for the highest CFM fans in the 120mm and 140mm sizes.
So far this what I found on Amazon:
Ultra Strong - 200 CFM 120mm fan
Bgears b-Blaster - 308 CFM, 140mm fan
Are the best CFM I can get? Any other choices out there?
241CFM, 120mm
I'm not judging. Maybe you're building a server that you'll keep in the basement.
But just in case this is meant to be in a PC, in your home... Seriously think about it for a bit longer. :)
Two of these:
120CFM, 38mm thick, 5.5W power consumption, 44dB.
2x44dB = 47dB
vs a single 241CFM one from the first link:
30W and 62dB
62dB is something you expect from a vacuum cleaner. Or when you drive at 140km/h in a car with poor soundproofing and people inside start to shout to each other.
Reactions: Meghan54
