Higher refresh rate than possible with DVI-D
bntran02
87
I'll try to keep it short...
I have a LG 34UC97 capable of 3440x1440 and 60Hz refresh.
I have an older video card Geforce 560 Ti. (I don't really game anymore)
Monitor auto detects 3440x1440 with 30Hz refresh. No problem.
I create a custom resolution and refresh with 3440x1440 @ 50Hz. Noticeably smoother. No problem!
I decide to go further than what's possible with the DVI-D spec and push 3440x1440 @ 60Hz and again it gets even smoother. This is definitely not placebo. How is this possible? What's the reason I can get data rates faster than the DVI-D spec? Would there be any negative side effects of pushing it to this rate?
Thanks
alcoholbob
6,390
469
Thanks
There are actually monitors that run Dual Link DVI at 2560x1600 @ 75Hz. So that would be equivalent to pushing 3440x1440 @ 63Hz.
videogames101
6,783
27
So in general you can run it faster than spec, but you might have connection problems. Might take some doing though, I remember you can oc your output chip somehow.
kevinsbane
694
Thanks
You're not exceeding the spec for dual link dvi.
bntran02
87
Thanks everyone! There's are all very helpful responses! I guess I didnt read the Wikipedia link regarding DVI thoroughly enough.
There is in fact no maximum spec for DL-DVI. SL-DVI yes, but it's a misconception that DL-DVI has a maximum spec that is twice that of SL-DVI
See this, for instance: http://overlordforum.com/topic/68-to...post/#entry621
Thank you very much for this link. A very interesting and informative read and I found references to your statement about no maximums. Thanks!
Black Octagon
1,410
No problem. Now, you said you achieved a real 60Hz OC with this monitor. Great if true. How did you verify it? In ToastyX's post that I linked, he was using Refresh Rate Multitool. That one still works but it's a little easier to use BlurBusters' TestUFO page. Did you use either of these?
bntran02
87
At the time of my post I used my eyeballs to verify. Then I later used testufo.com to verify again with real numbers.
It appears to be detecting 30,50,60Hz as I change my monitor's refresh rate.
