Higher gain wifi antenna, no better reception
russell2002
272
Hi,
I have changed from a standard antenna to a 15" 9db version as my wifi signal is very weak.
However I get exactly the same signal quality from the better antenna. I do however see twice as many networks with the new antenna.
Any ideas why ?
Thanks.
JackMDS
29,554
430
I assume you are talking about an Antenna on the client side.
If the signal is very low and noisy the Antenna would not help.
In such a case you are much better off putting it on the Router/Access Point side.
russell2002
272
Would I be right in thinking that a higher gain antenna will pick up more networks, but that those additional networks may be causing interferance with the one I wish to connect to.
And so a directional antenna with a lower gain may be more suitable.
And yes, its client side.
Thanks.
