- Oct 2, 2004
- 2
- 0
- 0
I have a an Asus K8V SE Deluxe and I am wanting to buy 2, 1GB sticks of memory. The current specs worry me and I wonder if they will work. I have to order them online, so getting them back to the seller would be a pain in the ***. I'd like to see if anyone may be able to tell me if this memory would work with the K8V SE Deluxe board. Here's the memory specs.
PC2100 266 Mhz
1GB DDR RAM
128x64 HIGH Density RAM <----This is the only thing I really am worried about.
184 Pin, Gold Leads
Non ECC, Non Registered
6 Layer low noise shield PCB Board
2.5V
CAS Latency (CL 3)
Double Sided DIMM
Again, the only thing I am worried about is if this High density RAM would work. The specs all seems to match and an Asus tech said it may work, but his response wasn't very convincing. I can't really spend a crapload of money on something that won't work and then pay to send it back. Thank you for any help!
PC2100 266 Mhz
1GB DDR RAM
184 Pin, Gold Leads
2.5V
CAS Latency (CL 3)
Double Sided DIMM
