Hi all,
I finally built my new system:
e6300, gigabyte S3, 1 gig of Transcend 667MHz JetRam, BFG 7600GT OC and an Antec TP 2.0 480W (trueblue) PSU.
First off, my cpu idles at about 54C and under load it goes upto 65C!! (Prime95 stable for 24 hours though)
And since I just couldn't sit still, I tried my hand at OC'ing it
and got it upto 2.33 GHz (333x7 and at stock VCore) and ran Prime 95 and it was still stable for 24 hours. (56-57C at idle and 66-67C at full load)
I was quite surprised to see that there was not much of a difference between stock temps and OC temps! I have one 80mm fan in the side of the case blowing air in and one at the back of the case blowing air out. I'm planning to get the CoolerMaster mini Aquagate R80 in a week or so.
Anyways, from reading many posts here and elsewhere I already know my temps are way too high but I was wondering about how I am Prime95 stable with such temps. Has anyone else faced this situation? I was always under the impression that Prime95 would crash a system that was running too hot! Hopefully things will cool down once I get the Aquagate in place! I will keep you all updated.
In the meantime I also want to add that this is my first EVER build and I would never have gotten off the starting block if it wasn't for this forum and the helpful comments that I received from some of you! This forum has been a real eye-opener in more ways than one! Thanks a bunch!
ps: I'm from India, where temperatures are normally quite high (about 30-32C now, in winter!) and my system runs in a non-air conditioned room. Just thought I'd put that bit of info out there as well!
