Loonmario
I used a Cooler Master Hyper T2 to start with and my temps are way too high. I upgraded from a Ryzen 5 1400 and the temps never got higher than 60 degrees. I installed a Ryzen 5 2600x and the idle temps were about 56 in the bios. I used Prime95 and I'm getting about 95 degrees on load. I reinstalled the cooler twice and same results. I'm pretty sure I installed it correctly (the thermal paste was evenly distributed) but just in case I installed the stock AMD cooler. The temps are pretty much still the same. I looked around on the internet and it seems a lot of Asrock boards are doing this but I haven't found a solution. I'm running the bios stock right now for testing. The computer hasn't crashed or anything weird yet but I just did it today. Any advice?
Ryzen 5 2600x (upgraded from R5 1400)
Asrock AB350 Pro4 motherboard (tried bios 5.0 and now 5.10)
2x8gb Crucial Ballistic 3000mhz ram
Sapphire RX 480 4gb video card
480gb Micron SSD
650w Corsair Gold PSU
Asus Blu-ray burner
480gb Micron SSD
Asus Blu-ray burner
