high temps caused by voltage problems
jack bauer
I have a a8n32, opty 170, and x1800xt512 w/ accelerox2, and have some heat problems. Someone suggested a possible voltage problem. They seem normal to me. How could I check them under load (ie during a game)? PCProbeII is only accessible at desktop.
Hi There!
To get them at the desktop you could use ATi Tool, and specifiy an OC with a long heat-up stage, and use Prime95 to stress your CPU at the same time, whilst using your volt monitor on the desktop.
MikeHP
What are the indicators of a volatge problem? I have a seasonic s12 500W, volt specs on idle:
Vcore 1.41 (used to be 1.38, not sure why the jump)
+12 11.97
+3.3 3.25
+5 4.97
