- May 23, 2002
- 16,928
- 8
- 81
We have a 2-sided gas fireplace in our house but it doesn't have any sort of fans built into it to disperse the hot air. This means we just have to rely on what radiates out from the glass on each side which doesn't really help to heat the room. There is electrical wiring that goes to the fireplace specifically for a fan, but it was not installed with a fan.
There is a decent size opening on top of the fireplace where I could easily put a couple small fans that would help blow the air from that section out into the room. I'm assuming that cavity gets pretty darn hot so I'm wondering if this is even feasible and if anyone know of any fans that can run in really hot temperatures.
I thought of just using some PC case fans but don't know if they'd basically melt if it gets too hot. I don't know how hot it gets for sure as I've never measured it but I'll see if I can do that at some point once we get it turned on this winter.
Anyway, does anyone know of any fans specifically designed to work in really hot temperatures or have any suggestions I can look into?
Thanks.
Thanks.
