http://www.liveleak.com/view?i=386_1278625810 this one won't buff out, doubt the driver lived at all..
Did you see it til the end? The driver
miraculously emerges with a god damn cell on his head.
Did you see it til the end? The driver miraculously emerges with a god damn cell on his head.
No, did you skip over to the end?, that's the bus driver walking back after checking out the wreck.. Also note the car that JUST squeaked by before the bus hit the rail!.
I am not so sure that was a 'normal' blowout. Look at the 30 sec mark and it appears that some pretty significant debris is in the road and the car drives over it and it actually pops the car off the ground and causes the blowout.
Was there a blowout? The tires look fine as the car is flipping over.
Kinda sad that no one stopped...
Yep, it's unclear if the tire itself blew out but in any event driver should have swerved to maybe avoid it. Sun's angle sometimes makes it hard to see thou..
ThisI am not so sure that was a 'normal' blowout. Look at the 30 sec mark and it appears that some pretty significant debris is in the road and the car drives over it and it actually pops the car off the ground and causes the blowout.
