actually the fastest laptop hdd at present is a 5400rpm model.Originally posted by: SunshineDaydream
Laptop hard drives are weak (7200RPM max).
Originally posted by: yodayoda
or you could go USB 2.0/Firewire and find a enclosure that has RAID 0 support
as soon as i said that, i went looking for it. sadly, i can't seem to find it. i found plenty of SCSI RAID enclosures, but no IDE RAID ones. it seems like a relatively simple device, but i guess there isn't the demand for IDE RAID like there is for SCSI RAID. maybe soon there will be a SATA RAID enclosure, as SATA and Serial SCSI are supposed to be compatible.
Any way to hook up either 15,000RPM SCSI or IDE Raid to a laptop (firewire or some other means)? I would like to do some video editing, but a laptop drive is just too slow.
Originally posted by: AgaBooga
What do you need that kind of speed for? You might as well just setup a desktop and then sync the laptop and desktop after working on either one. You could get a cheap Raid setup on the desktop easily.
