High Speed Drives - Recommendation
EagleKeeper
Discussion Club Moderator<br>Elite Member
Staff member
Oct 30, 2000
42,589
Client has handed me an open PO.
I need to spec two or three identical systems that are used for heavy data processing built around disk I/O
A 200 GB data base has to get sliced and diced in preparation for compression of real time use.
At present it takes 8-10 hours on a laptop. (4800 RPM) and the task manager at times will not even respond (example of the loading).
Majority of the processing is done by programs outside of my control w/ respect to optimization.
My gut feeling is that I want 2 super high speed drives in each system. One for the input side and another will be on a separate channel for output.
I will have a third small "normal' drive for the OS, etc.
They will be XP boxes.
The box (CPU/Memory/Video) is not the issue.
What drives should I look for that will have the the below specs for the slicing/dicing.
Speed should be 10K or 15K RPM that have at least 500GB capacity.
Harvey
Administrator<br>Elite Member
67
If cost truly is no object, it sounds like it's time for solid state drives.
STEC Mach 8 Solid State Drives:
STEC MACH8 Solid State Drive is revolutionizing the storage world by delivering to the users the ultimate level of reliability and performance in a fully integrated device.
At the heart of the MACH8 Solid State Drive there is STEC's leading edge controller able to address multiple flash chips simultaneously to achieve up to 100MB/s sustainable Read/Write speed.
The MACH8 product is embedding the Full Data Path Protection, STEC's proprietary set of algorithms capable to protecting the data wherever they are temporary or permanently stored.
MACH8IOPS 5-Year Warranty (see warranty terms)
MACH8MLC 3-Year Warranty (see warranty terms)
MACH8 3-Year Warranty (see warranty terms)
  • Industriy leading Solid State Disk
  • Patented Full Data Path Protection
  • Low power consumption
  • Non-volatile memory and no moving parts
  • Two Operating Temperature supported:
    • Commercial Temperature: 0 to 70C
    • Industrial Temperature: -40C to 85C
  • Drop-in replacement for traditional 1.8?, 2.5? and 3.5? drives
  • Support Serial ATA and Parallel ATA
  • Sustainable Sequential Read and Write speed up to 100MB/s
  • Optional MACH8IOPS version for IOPS hungry applications
They list 250 and 500 GB drop-in replacements for 2.5" and 3.5" SATA and PATA form factors with Read/Write performance spec'd at 90 - 100MB/sec.
Peter
9,640
Or, if funding doesn't allow, you want Seagate's latest Cheetah 15k series drives. They're by far the fastest traditional HDDs, with up to 168 MB/s actual (!) transfer rate and the fastest possible seek times.
