High quality UV filter make a difference?
NaOH
I know to invest in a higher quality polarizer. But does a a really high quality UV filter actually do anything besides protect the lens?
I'm wondering this question as well. Also, what are soem good brands for Polarizer/UV filters?
As far as most photography goes, they're just useful to protect the lens. With today's digital photos and all the tweaking people can do in processing, I wouldn't think they'd make any difference at all to the quality of the final photo.
That's what I was thinking. I took a couple of scenery shots with a cheap vivatar UV filter and it looked identical as if I used nothing at all.
I've only bought Hoya filters so far as I have heard good things about them. I think Tiffen and B + W are other brands to consider.
Yeah, for he UV filters I just get Promaster, Sunpak, or something like that. For circular polarizers I get Hoya.
Edit: Oh, and make sure you get the multi-coated circular polarizers. I think the Hoyas say super-multi-coated or something like that.
i've had some multicoated filters of both hoya's and B+W's, the B+W's tend to last longer IMO.
I personally don't use UV filters 99% of the time because I don't want the possibility of reducing image sharpness by putting an extra layer of glass into the mix. I find that lens hoods add all the extra protection I need.
BUT I will use UV filters by the coast where there's sand and salt spray, and during times where there's blowing rain.
Since I own pretty sharp lenses, I wouldn't want to compromise their sharpness by putting cheap filters in front of them.
I've been itching to try mine, but it's been so unnaturally hazy these last couple weeks that it wouldn't make a difference. Next time I'm in the mountains I plan on taking a couple comparative shots.
My polarizer is awesome, though. 🙂
