fUnc 1030
ratpad
3m precise
everglide attack/giganta
steelpad
icemat
I used to have a Ratpad and wouldnt go back, i really wouldnt say it only lasts a month, but it does lose its shiny, smooth surface after a couple. Another thing it does is scratch and wear down the mouse feet. At the time i thought it was well worth it, waaaay better than a cheapo foam + material/plastic job for gaming. weird thing for a mousepad though, its
noisy, and can get annoying when doing a lot of mousework unless you have headphones on.
But i replaced it with a func
🙂 Its much thinner so is more comfy for the wrist, there are two sides to it - one rough one smooth. the smooth side is better for accuracy, the rougher side better for speed - both sides are smoother than the ratpad though. It hardly seems to have worn at all, and scratches the mouse feet far less - very occasionally you can sort this by turning the pad over for a while so the new surface can smoothen out the scratches
🙂. The func also comes with a little cord-holder which at first looks a bit cheap, but it doesnt take long before you wonder why other mousemats dont have the tiny metal clip that is so functional. i wish they'd ditch the expensive packaging (yes, go to a lan and people with normal pads will stare at you if you take your pad in this packaging, and will think "what a pretentious pro gamer wannabie" if you dont own everyone in a convincing way- which tbf the pad actually will help you to do) and just make the thing cheaper though.
didnt try either mat with the "skatez" though, all the pads are obscenely priced (especially the func) without paying a fiver for a couple of inches of teflon sticky tape - most people who have had them seem quite impressed though. theres a
peice on dans data about mouse wax, i'd never put this anywhere near the func - the grain is too small - but would try it on the ratpad.
i moderate a uk fps gaming site, the topic comes up a lot. func wins pretty easy every time, with honerable mention to the 3m precise because while not many have tried it, those that have all seem to really like it. If you play a lot of FPS games, go for the ratpad. if you want a quality pad for fairly cheap, try a ratpad or everglide. 3M another possibility for either since its meant to be excellent, and reasonable cost but doesnt last long.
