High pitched noise
tara150
Hey all!
First time in a long time putting a computer together. I get it all put together, plug it in, and instantly get a very high pitched noise. I can't for the life of me remember what that is. Help!
Thanks,
Tara
imported_Phil
9,837
Is it coming from a small, black, round device on the motherboard? If so, that's the speaker and you need to read the manual to find out what that beep means.
TheGreenGoblin
216
You should power up the pc with the side panel removed. That should help you localize the problem.
It could either be a fan (cpu fan , power supply fan or northbridge fan) , hard drive , or pc speaker.
tara150
This high-pitched whistle is made *before* I even turn it on. Like when I first plug it in. It seems to be coming from the power supply box.
I hooked the power supply up to two other motherboards, and it still whistled.
I took a can of compressed air to the power supply thinking maybe it was just dirty. It still whistled.
Sigh.
imported_Phil
9,837
You have a faulty power supply. I would refrain from using it, as it may damage the components in your PC.
tara150
That's what I thought was probably the problem...Yep, haven't used it since I discovered its lovely opera of noises. ;)
Thanks for the help guys :)
