imported_plex
Ok, I posted this on hardforum and two possible answers were:
1) voltage leak on motherboard (motherboard going bad)
2) due to overclocking, the harddrive is working faster thus creating more noise (harddrive has to seek more)
Here is the problem:
Never notice this before but when I overclocked my machine, I get a high pitch noise that gradually becomes louder as I overclock higher. When I got my machine up to 2.5ghz territory, the high pitch sound almost sounded like an internal alarm going off.
Specs:
Athlon 64 3000+ (venice core?)
Chaintech VNF4 Ultra (nForce 4) motherboard
(2) sticks of 1g Corsair ValueSelect ram PC3200 DDR400
XFX 6800 XT
Lite-On 16x dvd burner
(1) 320gig Western Digital Caviar SE 16meg cache sata 2 (backup drive)
(1) 160gig Western Digital Caviar SE 8meg cache sata 2 (main drive)
Aspire 530w PSU
Far as what I did to overclock:
HTT lowered to 4x
FSB raised to 247mhz
memory divider set to 166mhz
ram posts at 416mhz
cpu posts at 2.2ghz
When I leave everything at default settings (not overclocked), the noise is there but not as bad as when overclocked.
It is not any fans causing this noise. I have stopped all the fans and the noise still exists. It is also not the PSU. It is possible it may be the harddrive going bad but I installed windows on the newer harddrive (320gig) and the noise still existed. It only happens in Windows.
It is also bleeding over into my onboard sound and whenever I open a folder or have activity, I can hear it through the speakers. Sounds like a slight pause then static (both from the speakers and placing my ear right next to it).
I'm stumped. I've installed fresh copies of Windows and nothing seems to be working.
Since the noise that is coming from my speakers sound identical to the ones from the case, I decided to cap the noise from the speakers.
http://www.specialmoose.com/noise.AVI
Again, it is not only coming through my speakers but also through the case.
Specs:
XFX 6800 XT
Aspire 530w PSU
HTT lowered to 4x
ram posts at 416mhz
cpu posts at 2.2ghz
