Hey, I just got a new 550w psu and when i turned it on, it started making this high pitched noise. However, it is working perfectly. Should I be worried or return it for a new one?
Inductor whine. Sometimes they will start to do that at audible frequencies. I don't think it's anything to worry about in terms of functionality, but yeah, do an RMA, before the noise drives you crazy. 😉
