High idle when I start my car?
JEDI
29,391
2,738
i have a 2002 chevy prizm. in the past when i start my car, my engine is at 1600 rpm. today in the afternoon, i noticed it was 2000 rpm. The temp this afternoon was 50 F.
Is this normal? If not, what could be wrong? (yes, i took it to the dealer a couple of weeks ago because my gas milage went from 32mpg to 25mpg. they said diagostics reported everything normal, and have no idea why my milage dropped 20%. it's been like that for 2 months :( )
so if i take it back to the dealer, and they still say the diags check ok, what could i tell them to check? (for both the high idle and gas milage problems)
WinkOsmosis
Banned
Sep 18, 2002
13,990
My 240sx decides what it idles at. Sometimes it changes on its own at a light, with the AC off or on, it always fluctuates between 600 rpm and 1000 rpm. Sometimes 1500 when I start.
Aug 23, 2000
15,509
OK, so i'm not the only one. lol
What year is yours?
Vortex22
4,976
While were on the topic of idling...
Is it normal for my Civic to idle at 500-600 rpm? It seems kinda low.
I'm in Florida btw, so it's almost always hot outside. It idles around 1000 when it's colder.
blahblah99
2,689
Does your have a mass air flow sensor or a MAP sensor? You could have leaky injectors, bad intake manifold gasket(s), leaky throttle body/plate, or bad idle air valve. The point is air might be leaking into your car at idle when it's not supposed to and that'll cause the engine to idle a little higher than it should. It could also be a bad coolant temperature sensor or the plug could be corroded and not make contact.
As for the problems with 240s, I know all models have notorious problems with the MAF sensor going haywire... so you guys might look into that.
Pepsi90919
the computer ultimately decides what it wants to idle at.
when the engine's cold the idle will naturally be higher because the computer wants the engine to be hot.
when the engine's hot there's no need to idle it as fast.
when i restart my civic's engine when it's hot it idles high for 2-3 seconds (initialization) then drops like a rock under 1000 rpm.
ThisIsMatt
Banned
Aug 4, 2000
11,820
That's perfectly normal...shows your engine is in good shape somewhat :p My accord idles at the same rpms, except when I start it after sitting for a while and the auto choke is on...
