PrinceXizor
I have a Powerleap PL-Pro/MMX Plus! and one of the caps came off. I went to solder it back on and noticed it looks like the cap has "blown up" on the bottom and needs replaced.
2200uF
6.3V
105C
However, I know that on CPU power circuitry, your ripple current tolerance should be extremely high and your ESR should be extremely low. They also should maintain well at high temperatures. Anyone have any suggested part numbers of caps that are used in current CPU VRM circuitry that will fit the bill?
Thanks!
P-X
2200uF
6.3V
105C
Thanks!
P-X
