what are you using to do the monitoring? It is quite possible the cpu and mobo temps are just being swapped. On my mobo, winbond 1 is the mobo and winbond 2 is the cpu and winbond 3 is the chip set. So, most monitors seems to want the make winbond1 the cpu temp even tho it isn't, at least in my case...
