High case temps
smopoim86
I have a sonataII with a pentiumD 820
The processor temps fall nearly 8 degrees when i remove the side off the case.
I have removed the ducht and taped up the rear vent and converted one of the 5 1/4 slots into an intake.
Any advice?
Idle temps: (case open) 42, (case closed) 46
load temps: (case open) 59, (case closed) 68
Is that normal for there to be that much of a difference in temps?
Graphics card gets a little warmer, around 3 degrees
System specs
Pentium D 820 2800MHz @ 3200MHz
Asus P5wd2-Premium
2x1gb Corsair ddr2 800
X800gto
