parablooper
I've been agonizing over which CPU cooler would be appropriate for my friend's FX-8350. We don't want to kill the processor, but we'll probably just run it through AMD OverDrive auto on a voltage boost and see what frequency pops out. Point is, we need a cooler.
By purchasing his computer parts for over $500 he received a $50 newegg gift card, which puts our total budget for this CPU cooler at a decent $100.
First, let me lay down the facts.
1. Right now he is on stock heatsink. It turns into a jet engine when under stress.
2. While our budget is $100, something cheaper would be preferable.
3. We want something that will be both quiet, and keep the CPU under 70C while overclocked.
4. The maximum possible heatsink height on his case is 160mm.
5. A 120mm/140mm radiator is preferable for CLC (as opposed to 240mm/280mm), since we don't want to deal with compatibility issues.
Now my two questions are:
1. What liquid/air cooling solution do you recommend?
2. Is it safe to mount a single-fan-width radiator (120mm/140mm) to exhaust at the top of the case? Or does that cause problems with the fan bearings?
